12mm acme lead screw
Discussion in 'CNC Mills/Routers' started by boskap, May 19, 2016.
  1. boskap
    boskap New
    hi
    Sorry my english is not so good
    my question is it possible to use a 12mm acme lead screw in c-beam
    because the 8mm 1m long are very soft i think
    one of mine already bent a bit
    thx for support
  2. dddman
    dddman Journeyman
    It is possible, but you'll have to make custom end mount
  3. boskap
    boskap New
    Ok thx
    must i use acme or can i use ballscrew too
    what ist the advantage of acme
  4. Rick 2.0
    Lower cost.
    The main issue is verifying that you can mount the lead nut to the plate and have the mounted assembly fit into the limited amount of space inside the track. You will need to custom machine some of the parts to achieve this. DumpsterCNC is a good source of information on the potential size of the fittings.
  5. boskap
    boskap New
    Ok thx
    I think the 250mm and 500mm 8mm acme is good
    But the 8mm x 1000mm acme is to soft
    So I want to check the 12mm
  6. hary
    hary New
    Hi.
    Did you find the 12mm x 1000mm Lead Screw ?
    I'm looking for a 4 start one (nut move 8mm per turn) but can't find them at a reasonnable price !
    Very strange they sell 1m long 8mm screw witch is very soft, but hardly sell 1m long 12mm !
    Any advice or seller on Ebay or bangood ?
  7. Gary Caruso
    Are you using the 1000mm TR-8's in tension? i see many people do them in compression when tension is much better.
    It is a matter of using the collar on the outer end instead of inner ends, but you might not have length to do so.
    Dani Rose likes this.
  8. hary
    hary New
    I need tension but also compression (actually the compression is more than the tension).
    I have no way to do something else. I have a lot of compression when the screw is driven at on end and the nut at the other end, 1m far away ! So of course it tends to do something like this : (I don't know how it's called in english, maybe buckle, flambage in french)
  9. Gary Caruso
    what I am referring to is where are your collars on the rods? are they on the inside of the bearings blocks (always the rod is acting in compression) or the outside (always in tension)
  10. hary
    hary New
    You might think I'm using the screw as normal use for 3D printer but I'm not.
    I'm using it to open and close a window, so I'm using it as to make a cylinder
  11. Gary Caruso
    Ok! yes you need a bigger screw for side and compression load then! I work with some big ones at work :)
    An option would be to use springs to keep the compression off the actuator..
  12. hary
    hary New
    Yes but the most compression needed is at the end when the distance is the biggest when the spring would be almost free !
    Any idea if it's possible to find some 12mm screw with8mm move per turn ? I found some but with only 2mm move per turn !
  13. Gary Caruso
  14. hary
    hary New
    Well, this seller might be the only one I found, but he is in US and doesn't ship to France !
  15. Gary Caruso
  16. David Bourne
    12mm is far stronger, I can supply TR12x3 with anti-backlash (POM) nut and mount that fits into standard C-Beam, but will need modified X, Y and Z plates, I can supply those too if needed or you can alter yours, but the plate design is not openbuild so please don't ask for the drawings.
    Send me a private message if interested, oh, I also provide a TR16x4 solution but these will not fit into C-Beam so you need to factor that in, again I do have X,Y and Z plates for this but again they are not openbuild so no drawings.
    Send me a private message if interested.
    Dave.
  17. ChadRat6458
    Any back lash nuts that use this lead screw and fit in the C-Beam? Is it possible to cut down the one that came with it?
  18. Rick 2.0
    You’ll probably need to make your own. The brass ones will have too much play. You’ll probably want something in Delrin that you can make to be anti-backlash. Look up Matthias Wandel’s Making Wood Thread Taps on YouTube.
  19. ChadRat6458
  20. Guillaume Rancourt
    Would you be able to supply the Anti-Backlash nut that attaches to the Gantry Plates on the LEAD machines, that fits a T12x8 ACME lead Screw? (4 start 2mm pitch) ??
  21. David Bourne
    I don't have a T12x8 Tap to re-thread the nuts, but if you can source one, that would be the easiest way to fit what you require.
  22. Giarc
  23. Guillaume Rancourt
    Yes that is exactly what i'm doing :)
