1/4" 6061 T6 Aluminum - Best deals...
Discussion in 'CNC Mills/Routers' started by UltiBots, Jul 3, 2016.
  1. UltiBots
    UltiBots Well-Known
    Hi All -
    In shopping around for 1/4" 6061 T6 Aluminum plate, I have found:
    Please add to the list.
    Thanks - Brad
    www.UltiBots.com
    CB3030 CNC
    Dewalt 611
    Elaire 1/8" Collet
    1/8" Single Flute Carbide End Mill
    Workflow = Fusion 360 & Cam > Chilipeppr > Tinyg
    Feeds & Speeds For 6.5mm 6061 T6 Aluminum Plate
    - All operations = Conventional Milling
    - Cutting = 25"/min (635mm/min), Ramp = 10"/min (254mm/min), Plunge = 8"/min (203.2mm/min)
    - Adaptive (bearing recess) = .4mm multiple depths, 0.2 deg ramp
    - Contour cut (bearing finish) = 0.1mm stepover finish and repeat @ 254mm/min
    - Bore cut (screw holes) = 0.25mm pitch, 0.1mm finish pass and repeat
    - Contour cut (perimeter) = 0.05 deg ramp angle, 0.1mm finish and repeat @ 254mm/min
    - Pocket cut (not used) = 0.25mm rough & 0.2mm finish, 3mm max stepover
  2. Jimmybuckets
    Jimmybuckets Well-Known
    I have found good deals on ebay
  3. Giarc
    I go to a local metal dealer. Doesn't matter what I buy, it is $3 / pound. it costs a couple bucks per cut, but i have been lucky and have found cut offs that were close to what i needed. Cheaper than online for me. Of course, not everyone has access to a local dealer but I would check your local area if possible. You may find some good deals.
  4. dirtdemon
    dirtdemon New
    I use online metals whenever possible and not on a time crunch. They have many different products available besides aluminum including a nice selection of plastics. They package everything very well for shipping as well. Plus they have mystery boxes called proto boxes that u can order by weight with random pieces in it. Got some nice bits a couple times doing that.
  5. UltiBots
    UltiBots Well-Known
    @Jimmybuckets - didn't think of eBay. @Glarc - good idea. I think there is a metal dealer in the next town. @dirtdemon - I have purchased 2X with Online Metals. Then I saw the prices of Midwest Steel for 12x12. No comparison.
