1/2" Router
Discussion in 'CNC Mills/Routers' started by Peteraff, Jan 18, 2017.
  1. Peteraff
    Peteraff New
    Hi
    Completely new to this and I was wanting to ask. Is there anyone out there using 1/2" router as opposed to 1/4".
    I want to build the ox and also want to know the maximum cutting depth.
    Thanks in advance
    Peter
  2. snokid
    snokid Journeyman
    The reason we use a 1/4" router is weight. The OX is a good machine, couple of problems with a 1/2" router weight, size.... You also don't need the power. You will be surprised how much power the 1/4" trim routers have....
    Bob
  3. Hytech2k
    Hytech2k Veteran
    I agree with snokid, I started out using a Dewalt 611, quite a lot of power for such a small package (just loud as hell). I upgraded to a .8kw air cooled spindle/VFD and noticed a significant increase in torque, the spindle bogged down much less than the 611 and was way quieter to boot.
    IMHO unless your building a very solid rigid machine you won't be able to run the feed fast enough to see the full potential of the larger more powerful router, you'll most likely see missed steps and a lot of flexing.
    Just my observation..
    Gerald
  4. Peteraff
    Peteraff New
    Thanks guys
    What is the maximum depth you can cut with you 1/4" router
    Thanks again
  5. snokid
    snokid Journeyman
    the router doesn't determine the max depth...
    the distance from the gantry the length of the bit and the strength of the machine determine the max depth.
    Bob
  6. Hytech2k
    Hytech2k Veteran
    Exactly what snokid said, with just a slight exception. You can get around having a weak machine by adjusting the DOC to a shallower cut and maybe slowing the feeds and speeds if possible, not very efficient but still do-able. The material will also play a part, HDU and foam are much more forgiving than walnut or red oak. Other factors can play a part in maximum depth cut as well, like does your z-slide extend below the X carriage, the thickness of the material your trying to cut, total length of the bit, thickness of spoilboard, unfortunately there's not just one easy answer....
    Gerald
  7. Peteraff
    Peteraff New
    Thank you
