- Sketchup / Laserweb4
- Machine Time:
- 20min
- 1/4" and 1/8"
- Feeds & Speeds:
- 40mm/s
- Wood flooring but any hardwood would work
So i wanted to use some wood flooring samples ive got from some awesome friends in the US and their size got me thinking they where perfect for the Mini Mill.
Since this boards are to thick for a ring i had to reduce the thickness before actually milling the rings out.
I also made a mistake, i wanted to make 6 rings but only ended with 3, not sure where exactly as the source seem to be OK.
