Beginner Tool /collet Drawer
Rating:
  • Machine Type:
    OpenBuilds LEAD Machine
    Software:
    Vectric
    Electronics:
    OpenBuilds BlackBox
    Machine Time:
    Lead 1515
    Bit or Laser Size:
    1/4” 2 flute, 1/8” 2 flute, 90 degree V-Bit
    Feeds & Speeds:
    80 In/min, .3 Inch DOC for 1/4”; 70 In/min, .15 Inch DoC for 1/8”
    Materials:
    3/4” MDF
    Simple pull out drawer to be mounted under the machine to hold the tools needed. Spots for all collets, and router bits. Collets ranging from .5mm to 13mm in both standard and metric. Bit can be stored in their protective packages, but still readable.
    total time on machine was under an hour with tool changes. Need to fill in the V-Carve letters to be visible.
Noah Trent, acho57, JayMcD and 12 others like this.
  1. Trent Paulk
    Awesome work! I'm curious, which spindle do you have that enables you to use such a wide range of sizes of collets? Are those ER11 collets?
  2. Dale Stewart
    Looks good and thanks for the idea.
  3. Self-controls
    How to you route the square holes as perfect that they look with the tools listed?
    1. Netechsys
      That was with the 1/8” end mill. There is a slight rounding, but not too bad. The cases of the shark bit fit perfectly. Even the cheap Chinese end mills I have fit snugly.
      Netechsys, Mar 12, 2021
  4. Netechsys
    Drawer part built. Rails mounted. Now to attach to bottom of torsion box. Enough room for all tools, hold downs, etc in one location.
    Images
      Stuart Godwin likes this.
  5. Mark Carew
    Really nice! If your able to share the file I am sure it will be a big help. I know I could use this :)
    1. Netechsys
      DXF File attached. Ill be attaching slide rails to the sides and then attach to the bottom of the torsion box so it can be pulled out to access everything, and pushed back to keep it all out the way and clean.
      Netechsys, Mar 10, 2021
      Darriel Fisher, MaryD and Mark Carew like this.
    2. Mark Carew
      Looking forward to seeing how you go about making the pull out drawer! Thank you for sharing the file
      Mark Carew, Mar 11, 2021
