Beginner Standing Nordic Trees
  • Machine Type:
    CNC Router
    Software:
    Vectric
    Machine Time:
    < 30 mins
    Bit or Laser Size:
    0.25" End Mill
    Feeds & Speeds:
    Various
    Materials:
    Ply Wood
    The Standing Trees file consists of three trees that slot into the base. Simple and effective! As this is a slot together project you will need to alter the slot sizes & fillet radiuses according to the material thickness you plan to use. It’s good practice to always create test slots first before cutting the whole part out so that you can weigh up which overcut provides the best fit (Refer to the Video for more information on this).
    I created a video for the Project here:
    I have attached a zip file which includes two sets of files to make this super easy to machine. The first set
    contains the vectors and toolpath information ready for you to output the toolpaths, for this option, you will need
    to either own Vectric software or download the FREE trial software, where you will be able to output the gcode
    for this project. You can download the Trial software here.The second set includes the vectors for you to use in your own CAD/CAM software package.
    Happy Making
