Beginner Sliding Laptop Shelf For Openbuilds Table
Rating:
Tags:
  • Machine Type:
    OpenBuilds LEAD Machine
    Materials:
    1/2" MDF, V-slot, gantry kit plate, 3d printed mounts.
    I built a 1510 table for my LEAD machine and wanted both an additional support beam for the table top and a pull out platform for my workshop computer. Two V-slot gantry plate kits and a 3d printed shelf mount provide a stable sliding system. The 3d printed mounts press onto the edges of the gantry plate (printed from PLA+ with 3 shells and 50% infill) and screws into the sides of the 1/2" thick MDF shelf hold it all together.
    To roll the shelf you will need:
    (2) V-Slot Gantry Kit - 20mm
    To add an additional support to a 1510 table you will need:
    (1) 20x60 V-Slot at 1680mm length (color of your table)
    (4) 60mm Inside-out brackets
    (28) M5 x 8mm Screws (these are in 10 packs on the store)
    (4) Single L brackets
    (4) MDF Screws
Giarc, Sun Tzu, Rachel Holley and 2 others like this.
  1. Mark Carew
    Thanks for sharing!
      PsycloneJack and Lloydsch47 like this.
