- Machine Type:
- Laser / Plasma
- Illustrator / LightBurn Beta
- Machine Time:
- 1min
- Default laser cut size
- Feeds & Speeds:
- 7mm/s
- 3mm Ply and Acrylic
This is a special request from my daughter, a simple to do process that can be applied to any word or shape.
Important to mention that i used a beta version of an upcoming laser software called LightBurn
The process is simple:
- Get the basic shape from the attached documents - Make sure you measure the ring size
- Modify it as needed
- Cut 2 of the small shapes in ply and the center one in acrylic
- Glue them together ( i use CA glue )
- Sand the faces and sides and added little bevel to the top
Attached you will find:
- SVG with ring shapes
- Ring size chart
Tony Fleming, sharmstr, rokasni and 4 others like this.
