- Illustrator / LaserWeb4
- Machine Time:
- 12 min
- 1/8" / 3.175mm mill end downcut
- Feeds & Speeds:
- 15mm/s
- 1/2" Plywood
1/4" screws
1/4" TNUT![]()
Im working on a new project and it only make sense to get a new set of clamps. Now i usually clamp from the top or with double sided tape but there are a couple of projects down the road that will need some side pressure, thus the P Clamps.
So this is what you need to do:
- Place your stock material and secure it - I used double sided tape
- Load the included LaserWeb4 Workspace
or load the also included svg to your preferred CAM software
- Clean up if needed and add some color to it !!!!![]()
SpringBob, Colin Mccourt, Award and 8 others like this.
