Intermediate Flow Meter
Rating:
  • Software:
    Fusion 360 & Openbuilds Control
    Machine Time:
    ~1 Hour
    Bit or Laser Size:
    1/4 Inch Flat end mill
    Feeds & Speeds:
    600-1000mm/min
    Materials:
    12.5mm clear Acrylic, aluminum, 3D printed PLA
    I almost just bought one for 6 dollars on Amazon with one-day free shipping, but where's the fun in that? Sooo lets take all day to make one Water Cooling Flow Meter from scratch lol.
    I just finished building a new CO2 laser using an Openbuilds Acro Laser platform as the base. I reinforced and built up the Acro so it could hold a CO2 laser tube.
    After running it a couple times, I really couldn't tell if the water cooling for the CO2 tube was actually flowing or not. I read somewhere that it doesn't take long to melt your tube if the water stops flowing. It was at this point I could hear the LEAD CNC behind me saying "Pick me! Pick me! I can cut acrylic" I gleefully drafted up the model in Fusion 360 and fed to the LEAD machine! Model files attached to this project if you'd like. Please check out the video, hope you enjoy!
    Screen Shot 2019-07-30 at 9.59.33 PM.png Screen Shot 2019-07-30 at 10.33.30 PM.png
  1. Mo Santos
    Great project!
      Dimitar Gunev and Jacob Tabor like this.
    1. Jacob Tabor
      Thank you very much!
      Jacob Tabor, May 31, 2020
  2. Ariel Yahni
    Awesome as always Jake.
      Jacob Tabor likes this.
  3. Mark Carew
    I thought that I was the only one machines talk to! LOL :thumbsup: Awesome project Jake. I wanted to ask you about sealing the plate for leaks. Did the CA wicked between do the job alone or did you need to add silicone around the outside? Thank you for sharing
    1. View previous replies...
    2. Mark Carew
      Thanks for the info Jacob That's are really nice way to sandwich acrylic together quickly and has me thinking of other cool ideas where stacked acrylic could be used for a project. Thanks again for the share
      Mark Carew, Aug 2, 2019
    3. Giarc
      Great project! I am curious, does weld-on solvent weld PLA as well? I currently use Tap Plastics Acrylic Cement for both PLA and Acrylic, but Weld-on looks like it may set faster and I am always in the mood to try something newer and better.
      Giarc, Aug 11, 2019
    4. MHMTechServices
      To glue acrylic to acrylic I use pure acetone. You can pick it up in almost all stares that sell to hair and nail boutiques. Clamp the parts together and with a syringe, run a little acetone along the joint. It will seep in and welds very well.
      MHMTechServices, Aug 12, 2019
      Jacob Tabor and Mark Carew like this.
