The first cut out of my machine, a set of templates for hand building a guitar. Why make templates when I could make the guitar? Good point
- Machine Type:
- OpenBuilds LEAD Machine
- Fusion 360, OpenBuildsCONTROL
- Electronics:
- Other Controller
- Machine Time:
- 50 minutes
- v-bit, 1.5mm flatend mill, 3/16 mortise bit
- Feeds & Speeds:
- v-bit: 2000
1.5mm diameter flatend 4 flutes: 1000
3/16 single flute mortise:1500
- 9mm MDF
I challenged myself to a some complications, but they turned out great:
1st, make all parts from a single MDF sheet. This was more of a Fusion challenge, but learning to work with components was key.
2nd there are four operations: trace, bore and two 2d pocket operations.
3rd, multiple operations means changing bits mid-job, wich wasn't that complex nor difficult really.
OpenBuildsCONTROL is awesome. I won't stop repeating this.
Attached pics shows a render out of Fusion 360, and the MDF cut fresh of the machine.![]()
Beginner Electric Guitar Router Templates
Workshop Project created by sergiomajluf, Sep 30, 2020
Tags:
Jamye Few, Scott Boutilier, Jason Calvert and 11 others like this.
