Beginner Dragon Themed Frame (picture Or Mirror)
Rating:
  • Machine Type:
    CNC Router
    Software:
    Vectric Cut3D, Vectric V-Carve, bCNC
    Machine Time:
    9-10 hours
    Bit or Laser Size:
    1/4" End Mill. 1/8" ball nose End Mill, 1/8" straight End Mill
    Feeds & Speeds:
    80 IPM roughing pass, 80 IPM finish pass, 50 IPM cutout pass.
    Materials:
    Walnut wood, Formby's Tung oil finish.
    A 3D carved Dragon Frame I did recently on the Lead 1010 machine. The model was picked up on Etsy found here: 3d STL Model for CNC Router Engraver Carving Machine Relief Artcam Aspire "gorgeous picture frame" I know this file can be found for free in some forums on the web, but Please try to support the model creators if you can.
    I am not going to go into details on this project, as I have already done so on my other projects posted here. The same methods apply to this carving. Check them out if you need help with model/ toolpath setup.
    Here is my canvas laid out, ready to be transformed into art.
    Using a 1/4" downcut end mill bit, I begin the roughing pass.
    Once that completes, I swap out bits to my 1/8" ballnose end mill, reset my Z zero and run the finish pass.
    Swap out bits again after the finish pass to an 1/8" straight cut end mill for the cutout/ profile tool path. Remember to set your Z after any bit change!!
    I then added a coat of Formby's Tung Oil Finish.
    I would like to add a mirror, or at least some kind of reflective backing to it, someday............
    (NOTE) I really should have ran a 2mm tapered ball end on this. It would have left a ton more detail in the finish pass, but would also add multiple hours to the project. :(:(
    Hope you all like this project. :)
    Final.jpg IMG_20190505_080033948.jpg IMG_20190505_081543053.jpg IMG_20190505_120109381.jpg rouging complete.jpg With Finish.jpg IMG_20190505_192713713.jpg IMG_20190506_171037191.jpg
  1. Colin Mccourt
    Absolutely fabulous..well done.
    In fact I was looking at this exact model the other day.
    Can you give me the Timber size and thickness used and the size of the finished model?
    Love it! Thanks for posting...
    On reply, I will purchase this model from the proper source.
    Regards
    C
      Jack D likes this.
    1. Jack D
      Thank you. The wood was approximately 1.4" x 11" x 22"
      The finished model is 1.1 x 11 x17 to maintain the aspect ratio. If I would have glued up a bit wider piece of wood, I could have utilized the whole thickness and length of the lumber. Could have been 1.4' x 14' x 22' A 1" thick piece would end up as 1" x 10" x 15.8" Hope that helps.
      Jack D, May 23, 2019
      Colin Mccourt likes this.
    2. Colin Mccourt
      Cheers Jack for the prompt reply, I have just purchased the model from the same source as you quoted. Now I need to find a nice piece of dark hardwood and hopefully, I can replicate your efforts. I ran a trial setup toolpath through Vectric software and your quite right in saying that a smaller bit seems to give more definition but at a price (time). Thanks again
      Regards C
      Colin Mccourt, May 23, 2019
  2. blindflight
    Great build, think your in the "LEAD" ..
      Jack D likes this.
    1. Jack D
      Thank you.
      Jack D, May 17, 2019
  3. MFCarew
    Really cool build Jack. One of a kind frame for sure.
    1. Jack D
      Thank you Sir! I just love the 3D carvings. The Lead 1010 has not missed a single step anywhere. That's impressive!
      Jack D, May 15, 2019
      MFCarew likes this.
  4. MaryD
    Looks great especially after the oil
    1. Jack D
      Thank you.
      Jack D, May 14, 2019
  5. GrayUK
    Just how long did this all take? :rolleyes:
    1. Jack D
      About 9 hours or so, which isn't bad.
      GrayUK likes this.
