Quality Disclaimer: I know this lacks some pics, a video and more instructions, but this is a really quick build, that happened unplanned - sorry! Shout in the comments though, if enough people ask I'll make a second one and take step by step pics!
- LaserWeb4
- 4.76mm router bit
- +-500mm of 38x38 pine (or any offcut suitable for the upright)
19mm Shutterply (cnc'ed to bracket parts)
1 x M8 bolt and nut
Concrete Mix
Bucket to use as mold
Bucket to mix concrete
1) Cut a suitable piece of offcut wood to serve as the upright
2) Mix some concrete
3) Prop the upright as vertically plumb as possible in the center of another bucket
4) Pour approximately 100mm deep concrete around the upright and leave to dry
5) Remove the base from the mold
5.1) Optional - Get distracted and leave it sitting on a messy table for a week till you get back to it - ie excuse the pic (; lol)
6) Mill out the bracket parts (LW4 JSON Exports attached)
CNC Operations: Download the attached ZIP files, and open each JSON in turn under github.com/LaserWeb/LaserWeb4-Binaries -> Files -> Workspace -> Load then generate gcode
7) Sand all the parts to remove splinters and burrs
8) Assemble the mortice and tennon joint with glue, leave to dry
9) Drill a 10mm hole in the top of the Upright
10) Assemble!
11) Mount camera with a 1/4-20 thumbnut
Patrick P, MaryD and Alex krause like this.
