Intermediate Cancer Awareness Pendant
Rating:
4.33333/5,
  • Software:
    Illustrator / Vectric Aspire / Vectric 3D / LaserWeb4
    Machine Time:
    7min aprox
    Bit or Laser Size:
    1/8" / 3.175mm ball nose
    Feeds & Speeds:
    Feed 25mm/s - Plunge 8mm/s - Setting #1 Dewalt 611
    Materials:
    Hardwood
    I wanted to dive into some 3D milling and found the perfect starting project for it. I also wanted too see whats all the fuzz about Vectric software that people seem to love.
    I categorized this project as intermediate because of the 3D milling but in reality its very simple and i did as follow:
    - Searched for a ribbon image on google, something that i could easily accommodate if needed
    - Loaded it into AI, to modify a little the curve angle
    - Opened Vectric Aspire, loaded the vector file and used the simple 3D command to do the shape
    - Saved the file as an STL
    - Opened the STL into Vectric Cut3D and created the toolpath. Exported it as a gcode in mm
    - Placed my stock hardwood that was roughly 7mm thick onto my MiniMill using doble sided tape
    - Loaded the gcode file into LaserWeb4 and executed it.
    - Removed the tabs, cleaned the edges, sanded the surface just a little but left some of the bit marks to show some "scars". Then added some was and polished it slightly.
    Just out of the Mill
    I was amazed but how simple Vectric tool are for creating 3D object and i will be doing a video soon of this process to how that.
    Of course the little MiniMill aka "TANK" made this all possible!!!!
    Included Files
    - Gcode (nc) file if you want to create the project as is
    - Vectric file
    - Vector file
    - STL file
    20171021_090611.jpg 20171021_090623.jpg 20171021_084124.jpg 20171021_084134.jpg 20171021_090553.jpg
  1. Mark Carew
    Awesome! thank you Ariel
