- Machine Type:
- OpenBuilds MiniMill
- Inkscape, Fusion 360, OpenBuilds Control
- Electronics:
- Other Controller
- Machine Time:
- 20-45 minutes each
- 1/8", 1.3mm, 3.0mm, 0.25mm (tip)
- Feeds & Speeds:
- 1250 mm/min 12000-20000 rpm
- 5.4mm cast acrylic plate (sold as 1/4")
I cut these on my modified mini-mill. (It is much more like a C-beam machine now.) I had a new dust boot and it worked great at preventing the spray of acrylic chips on my machine and shop.
I found some of the designs as svg's online. The others, I converted from jpeg's to svg's using the free program Inkscape. I imported each svg into a sketch in fusion 360, added an outline, and then used f360's manufacture environment to create the toolpaths and export the g-code.
I used OpenBuilds control to load the gcode and control the cuts.
Shaolin357, Draikes, Ariel Yahni and 2 others like this.
