- Machine Type:
- OpenBuilds ACRO
- LightBurn, Fusion 360
- Electronics:
- Other Controller
- Machine Time:
- Custom ACRO CO2 Laser
- 40 Watt Laser
- Feeds & Speeds:
- 800mm/min
- 1/8 Black acrylic, white PLA
So I needed to make something just for fun the other weekend, and this is what happened.. I give you the most useless, cutest, little AAA battery dispenser evah. I cut all the pieces out with the CO2 Laser and welded the pieces together with WeldON Acrylic solvent. Then 3d printed the little white handle/crack gear. The coolest part for me is the crank, I really like that I could make a spring out of the acrylic The fusion 360
models are included below. Thanks for checking out the video, please follow me on Instagram @Jakeslabnc
Nukelab, Matthew Bates, MFCarew and 1 other person like this.
