The Ornaments file is a two sided project containing a Christmas tree and a snowman that were created using the Turn Modeling tool. In the project we use the asymmetrical dowel hole method to create correct alignment in X and Y when the part is flipped over, it’s the same method that is taught in the two sided tutorials
- Vectric
- Machine Time:
- < 2 Hours
- 0.25" End Mill 0.125" Ball Nose
- Feeds & Speeds:
- Various
- Cherry
I created a video for the Project here:
If you don't own Vectric software you can download and cut this project using the FREE Trial Version of VCarve which can be downloaded here.
rokasni likes this.
