Tapping the End holes on V-Slot Openbuilds extrusion can be tricky, keeping the tap straight is a challenge, I have created A tap holder for each V-Slot profile currently available. these Holders have a 5mm bore, these can be drilled out larger if your tap shaft is 6mm or 1/4"
the holders cover 20mm of the extrusion to keep it square and straight.
Tap holders created for all profiles. 20x20, 20x40, 20x60, 20x80, 40x40, and C-beam
Designed by Adam from Makerparts.ca
V-Slot Tap Holders 2018-05-30
Tapping Made easy
