This plate was designed in Fusion 360 and can be downloaded in nearly every major design format at the link.
- Bit Size:
- 1/8"
- Feeds & Speeds:
- 300mm/min, 18k rpm
- Material Used:
- G10
This is an alternative X-Gantry plate for C-Beam machines. 1/4" thick material can be G10, steel or aluminum. One side is counterbored by about 2.5mm so the plate can sit flush against the Z-axis assembly without washers/spacers for the heads of the screws. There are 8 large wheels total and 4 mini v-wheels.
All 4 mini v-wheels are on eccentrics so the large wheels can be tightened properly then each mini wheel subsequently tightened. This plate grips each C-Beam rail from both the inside and outside which really helps remove lateral deflection in the C-Beam builds.
It is best to fully loosen the inside wheels and tighten up the large v-wheels first. Once the preload of the large wheels is set, then adjust the preload of the mini-wheels. Once all the pre-loads are set, install the anti-backlash nut block and continue with the build.
*IMPORTANT NOTE:
- The mini-wheels require 2 precision shims on each wheel for proper alignment with the large wheels.
- 30mm+ screw lengths are needed for the large wheels.
![](data/resource_icons/0/205.jpg?1468519307)
Ultra-Rigid G10 X-Gantry Plate for C-Beam 1.0
1/4" thick gantry plate with 12 wheels and a wider base.
