"This program can load a standard STL file, or a Image file (JPG, BMP, PNG, TIF) and output a comma-separated values file (CSV) that contains a 3D toolpath that will trace the surface. What good is that? Well, if you are using Vectric's V-Carve Pro (version 7 or greater) this allows you to read in 3D toolpaths that can be machined using CNC equipment. Normally, V-Carve Pro is restricted to 2D carvings, and 3D work is reserved for their 'flagship' product, Aspire. With the STL + Image Converter, you can do this with VCP, and see the final products with Vectric's famous previews. It can convert to CSV files in a matter of seconds.This package is a stand-alone executable program, so please do a virus check before running this program."
Not written by me but a cool program to convert STL's and images.
The programs are free but if you find these programs useful please consider the donation for the author... Help keep low cost software alive....
Check out more info here :
http://paulrowntree.weebly.com/stl--image-converter.html
STL & Image Converter 2014-12-06
