Just a quick clamp that has an overall dimensions of 40mm x 130mm. It uses a threaded insert for the pivot point and 1/4-20 hardware. The resource has Freecad, dxf, stl, step, gcode and svg files. Also included is a parts list in a spreadsheet that has links to Amazon for the threaded inserts and Google info of the 1/4-20 hardware that I picked up from Lowes. I was able to cut 40 from one sheet of 1/2in x 2ft x 2ft Birch Plywood.
- Bit Size:
- 1/4in 2 flute End Mill
- Feeds & Speeds:
- Default makercam so 60ipm feed, 30ipm plunge
- Material Used:
- 1/2in x 2ft x 2ft Birch Plywood
Plywood Clamp 2017-06-30
1/2in plywood clamp with threaded insert
