C-Bot
  1. Les Dollahite
    I think the Raps128 and the SD6128 are basically rhe same drivers from what I read but don't hold me to that. Just getting started. I was looking at 1/32 or 1/64 myself but I think 1/32 is just fine.
  2. AK Eric
    AK Eric Journeyman
    Right now I'm testing at 90mm\sec just fine, which is already way faster than I could do in Marlin. I'm still tuning stuff in the firmware & stepper driver voltage (had to up the extruder to .70v from .55, or it did some skipping at that speed). Once I get all that sorted I'll try to push it higher. Since my Replicator1 does 120mm\sec just fine, that's my goal ;)
  3. AK Eric
    AK Eric Journeyman
    They are, but you have to set some sort of 'invert' option on Repteier when using the RAPS128's for some reason.
  4. Les Dollahite
    Ues I read that in the RADDS user guide. "CAUTION: Inverted activation signal Enable = HIGH (at Pololu drivers enable = LOW, invert in firmware!)"
    guess they are set up reverse of soe other drivers
  5. Carl Feniak
    Carl Feniak Journeyman
    #1835 Carl Feniak, Mar 4, 2016
    Muh_3d likes this.
  6. Sk8rSeth
    Sk8rSeth New
    thanks carl!, ill add onto that!
    Polycarbonate high tolerance CNC Mini v extreme wheel kits for v slot linear rail system-in Other Mechanical Parts from Industry & Business on Aliexpress.com | Alibaba Group
    50pcs/lot 623ZZ bearing 623 ZZ 3x10x4 Miniature deep groove ball bearing 623 2Z ZZ bearing 623Z-in 3D Printer Parts & Accessories from Computer & Office on Aliexpress.com | Alibaba Group
    US Ship 10pcs Nema 17 Stepper Motor Bipolar 84oz.in(59Ncm) 4-lead 3D Printer CNC
    http://www.amazon.com/gp/product/B006LW2NJM?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
    free shipping PU gt2 belt gt2 timing belt 6mm width 5m a pack for 3d printer-in Transmission Belts from Industry & Business on Aliexpress.com | Alibaba Group
    and to my surprise, these werent the typical fiberglass strand filled GT2 that i was used to, these are STEEL belted, so they are extremely stiff and dont stretch nearly as much as i was used to. a really pleasant surprise if i do say so myself.
    same thing goes that Carl said, try and buy what you need from the openbuilds store whenever possible, the quality is controlled and is extremely good. whereas with these chinese sellers, quality may be good, but there is no way to guarantee that, let alone guarantee that youre even getting the product you ordered. so buy with a cautious head
    Muh_3d, TechGirl and Carl Feniak like this.
  7. Chris Roadfeldt
    Chris Roadfeldt Journeyman
    I'm going to use the same cable management setup you have. May I ask where you got the model for the cable chain and the various pieces for it from?
  8. Elmo Clarity
    Elmo Clarity Journeyman
    The cable chain links I got from Thingiverse (printrbot open cable chain. by eddiema). The project was for the printrbot, but I have used the links and modified mounts for other uses. I have modified the anchors for each application and designed the other mounts.
    The snap-on covers are ones I designed from another one I found (think it was Thingiverse but not sure). I modified it to be taller and added some ribs to allow it to be printed on its top instead of the side like the original one was.
    I can share the files if you are interested.
    Muh_3d likes this.
  9. Elmo Clarity
    I printed out the reworked Z side brackets and got them installed this weekend. There is a world of difference in the stability of the bed compared to before. While I can still deflect the ends of the arms, it takes a lot more effort and I can't move it as much as before.
    I ordered some brass nuts for the lead screws and those should be here tomorrow. I have the mounts printed and hopefully will get that installed and working soon.
    Muh_3d and Carl Feniak like this.
  10. Elmo Clarity
    Got the spring pack and found the stiffest spring in there. It seems to be feeding better now, but then it started feeding correctly when I replaced the original spring. I have not had the greatest luck with this extruder. Once I get the bed upgrade finished, I will be able to test out the extruder some more.
  11. Chris Roadfeldt
    That would be great, thanks!
  12. Elmo Clarity
    Okay. I think this is all of them. Let me know if I missed anything.
  13. AK Eric
    AK Eric Journeyman
    For anyone interested, I got my "switching to Repetier / RADDS" blog post up:
    http://www.akeric.com/blog/?p=3704
    Still doing a lot of Simplify3D profile configuring, but it's been chugging away just fine.
  14. Chris Roadfeldt
    Awesome, thanks! Printing them out now. :)
  15. Elmo Clarity
    Oh. Probably should have mentioned this earlier. I have printed the links in both PLA and PET-G. Personally, I like the PET-G ones better. They have more flexibility and make the links easier to connect together. The PLA ones were really stiff and hard to link.
  16. Carl Feniak
    Glad you're back up and running. Sounds like you had a pretty good experience with the Repetier. Excellent blog as usual. Did you draw that Mech v1.2 wiring diagram?
  17. AK Eric
    AK Eric Journeyman
    Thanks! Yes, Repetier has been a breath of fresh air compared to Marlin. I mean, they actually have a dedicated forum... ;)
    I did not draw that, the original is here:
    http://doku.radds.org/wp-content/uploads/2015/02/RADDS_Wiring.png
    I link to it above the image in my blog (via the text above the pic), but I made a copy for my blog for safe keeping. One of the reasons I like the RADDS board so much is that there's so much good clear info for it available.
    My only real issue right now is delamination when the PLA filament cooling fan kicks on: It's something I've never experienced before... Cooling fan kicks on, and filament does not want to stick... at all. Even at very low fan speeds. Completely perplexing since with my rep1, I can have the fan just blasting right at the nozzle. Of course the fan on my cbot is 24cfm (vs the 5cmf on the rep1), but I've moved the fan 2.5" back from the nozzle and removed all ducting,,... even at 10% delamination happens.
    But, this all new electronics & firmware, with a .4mm nozzle that I've yet to use on the bot, so some learning is expected. With the fan off it's been printing great, just having a hard time (as expected) with non-cooled overhang using PLA.
    devers6 likes this.
  18. Matt Mathias
    Matt Mathias Well-Known
    Hey all, I have been hovering around here for a while. I am about to start my build and am super excited. Carl / everyone I cannot tell you how much I appreciate the work you have put in, you guys are all awesome. I just have a few questions.
    1) Have we considered creating a real forum or Facebook group for this thing. This 63 pages of stuff is getting more than cumbersome to search through. Having a dedicated forum would make it a lot easier to have threads like "Flex3Drive + C Bot", which is something I have ordered and plan on experimenting with.
    2) I am also going to be playing with FSR end stops, BLTouch, and probably lasers. Has anyone else done anything with this stuff yet? Any advice?
    3) I have a TEVO Tarantula that I have managed to modify enough to be able print Nylon pretty darned well. Has anyone tried printing any of the brackets / parts for this printer in Nylon? I am using Taulman 910 Alloy and I am curious if others have tried that or think it is worth it.
    Thanks!
    -Matt
    P.S.
    I am more than happy to setup/run/pay for a dedicated forum for people interested in this printer if everyone thinks that is a good idea, but I am new here and I don't want to pre-empt anyone or step on any toes.
    trublu832 likes this.
  19. grat
    grat New
    I'd favor a google group, personally, but I don't know how popular that is.
  20. Matt Mathias
    I think a google group could be great, just about anything but one long thread with 200+ topics would be really.
  21. AK Eric
    AK Eric Journeyman
    I'd +1 a Google Group.
    You're a victim of your own success @Carl Feniak ;)
  22. Matt Mathias
    I see what you did there :)
  23. Matt Mathias
    in the re-work STL files I only see one XY motor mount, and it says to only print one of them....what am I missing?
  24. Carl Feniak
    @AK Eric @Matt Mathias @grat @Chris Roadfeldt @trublu832 @adamcooks @Elmo Clarity
    Yeah, I think a different environment could be a lot more effective at managing the further development and discussion of this project. As an open source project it allows lots of people to contribute and improve on the original design, however, without an effective environment to manage the improvements, the design becomes fragmented and too unwieldy to follow.
    As a soon to be first time father I would love to see a workspace that allows multiple people to manage/contribute to the same project as well! Since only I have access to update the files it is cumbersome for others to improve on the design here on OpenBuilds without posting a completely new build.
    What would be great to see:
    -General discussion forum
    -Categorized topic specific forums. Ex. Controllers, Software, Hotends and filament drives, Building, etc.
    -A "parts center" that contains groups of parts and the ability for people to add their improvements and remixs, along with an explanation of them and other documentation
    -An interactive BOM that the community can manage as links break or new sources (or better parts) appear <-- such as controller beyonfdRamps1.4! ;)
    -Ability to have multiple "admins" so others can edit
    -Links to build blogs and such. Priceless as build guides are a lot of work to make and keep up to date.
    How much of this is doable in a google group? Any other environments you'd recommend?
  25. Carl Feniak
    Hmm, there is only one in there? I'll have to fix that tonight. With the new stl file approach I should have made two separate files each reading x1. If you need it ASAP, you can open the 123D file and export the stl.
  26. Elmo Clarity
    I have never been a big fan of Google Groups. I have been on some forum software that allows you to filter messages to ones with pictures and file attachments. That would help, but not sure where you can find a forum host with it.
  27. Matt Mathias
    I can use the 123D files that is no problem,, I should have looked there LOL.
  28. Matt Mathias
    I was thinking of something like this: NodeBB Forum Software | Drive user engagement with a modern community platform. I can use the developer edition and host it on Heroku for cheap to free.
  29. Chris Roadfeldt
    +1 github - For community updatable files, BOM, CAD, Documentation, wiki, issue tracking. Only thing it really lacks is a forum. I like openbuilds, but agree this project has probably out grown it.
    +1 google groups - for the forum
    EDIT: I just did one thing that bugs me about google groups, I can edit this post.
  30. adamcooks
    adamcooks Well-Known
    You can edit your post in my google group. I am the manager of the CTC 3D Printers group. I think that github and google groups are both good destinations, possibly both.
