OpenBuilds Enclosure Series
Discussion in 'Other Builds' started by OpenBuilds, Oct 6, 2020.
  1. Iandoubleyou
    Hi Mark - the dxf file shows the 5x5 notches in the top panel but not the notches you mention for the doors - the assembly video also doesn't show any notches for the doors - is there an updated dxf?
    Many thanks!
  2. Mark Carew
    Hello, you are correct the top panel will need them but we got rid of the need to notch the doors (it was a pain to do) when we strengthen the doors with the corners. So they are no longer needed.
    Iandoubleyou likes this.
  3. residentdj
    what are the panel dimensions for 1010 with the High Z mod?
