Y-1200 Build
The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm.
The recommended power output is 60-90W, this can also be increased with the use of an extension box.
Y-1200 co2 laser
Build in 'Laser Cutter Builds' published by Gareth90, May 31, 2022.
Y-1200 Build The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm. The recommended power output is 60-90W, this can also be increased with the use of an extension box. designed by furtherfabrication ROB CHESNEY FREELANCE INDUSTRIAL DESIGNER.
Build Author Gareth90, Find all builds by Gareth90
ROB CHESNEY on youtubeInspired by
ROB CHESNEY -
Qty Part Name Part Link Comments 1 80W PSU CO2 Laser Power Supply https://www.cloudraylaser.com/products/cloudray-80w-110-2... Link 1 Cloudray 50W CO2 Laser Tube https://www.ebay.co.uk/itm/402312718571 Link 1 Openbuilds BlackBox Controller https://ooznest.co.uk/product/openbuilds-blackbox-control... Link 1 12/24V 250W Power Supply https://ooznest.co.uk/product/250w-power-supply-fan/ Link 1 CW-3000 Water Cooler (S&A) https://www.google.com/search?q=CW-3000+Water+Cooler+(S%2... Link 1 Laser Head and Mirror Set (Cloudray) https://www.cloudraylaser.com/products/cloudray-c-series-... Link 1 AC60 HAILEA AIR PUMP 60L/min https://www.ebay.co.uk/itm/261994536504 Link 1 Y-1200 Build Guide https://www.furtherfabrication.com/resources/y1200-build-... Link 1 Y-1200 Parts List https://www.furtherfabrication.com/resources/y1200-partsl... Link 1 Y-1200 CAD MODEL https://www.furtherfabrication.com/resources/y1200-cadmodel Link -
