Below is my 3D DeltaBot printer project.
Full description, detailed write-up, G-Code files and CAM files here: Make a 3D Printer using a CNC router - the "Deltabot"
It uses three 750mm 20x20mm v-slot rails, 9 v-wheel kits and 3 smooth idler pulley kits.
The base and top are MDF (medium density fiberboard). the carriage and end effector are ABS plastic. Arms are 6mm x 285mm carbon fiber rods with neodymium magnets.
Attached are the DXF files.
v-slot rail in MDF
MDF base
The carriage design.
Smooth idler pulley kit
UPDATE: The Repetier firmware working great now.
Hotend purchased and end effector redesigned.
prints great. Here are sample pictures of printing a 5 layer gyroscope fidget toy.
V-slot and MDF DeltaBot
Build in 'Delta Bots' published by mrtinkerer, Aug 31, 2016.
This is a deltabot 3D printer build using CNC routed MDF and v-slot rails. Full description found in instructables.com.
BrokenPoet, Mikewb, Erdinç Parlak and 1 other person like this. -
Build Author mrtinkerer, Find all builds by mrtinkerer
To challenge myself. I don't even know what I would use it for.Inspired by
Kossel and Rostock Delta -
Qty Part Name Part Link Comments 1 1500 mm 20x20 V-slot rail SKU LP-210 http://openbuildspartstore.com/v-slot-linear-rail/ Link This will be cut exactly in half 1 1000 mm 20x20 V-slot rail SKU LP-190 http://openbuildspartstore.com/v-slot-linear-rail/ Link This will be cut to 750mm length 9 Delrin V Wheel Kit SKU 500 http://openbuildspartstore.com/delrin-v-wheel-kit/ Link If using 4 wheels per carriage then 12 will be needed. 3 Smooth Idler Pulley Wheel Kit SKU 550 http://openbuildspartstore.com/smooth-idler-pulley-wheel-... Link For the belt 16 GT2 2mm Timing Belt SKU 470 http://openbuildspartstore.com/gt2-2mm-timing-belt/ Link Cut into 3 equal lengths. 3 GT2 (2mm) Aluminum Timing Pulley - 20 Tooth SKU 21 http://openbuildspartstore.com/gt2-2mm-aluminum-timing-pu... Link Goes on the stepper motor. 15 Cast Corner Bracket SKU 490 http://openbuildspartstore.com/cast-corner-bracket Link 6 corner brackets at the base and 9 on top. The tabs will need to be shaved off. 1 Tee Nuts (25 Pack) SKU 50 http://openbuildspartstore.com/tee-nuts-25-pack/ Link with v-slots you will need t nuts. -
