Build List
LEAD 1010 PLASMA Add-On
Apr 26, 2024 at 9:32 AM
Category
OPENBUILDS MACHINES
Build Progress
Build Complete!
LEAD 1010 PLASMA Add-On is a great modification you can do for your LEAD 1010 to convert it into a metal cutting monster machine!
LEAD Lathe
Sep 17, 2022
Category
CNC LATHE BUILDS
Build Progress
Build Complete!
Dragon Plasma cutter
Oct 8, 2018
Category
Plasma Cutter Builds
Build Progress
Build Complete!
1500x1000 CNC Router
Aug 10, 2021
Category
Cartesian Style CNC
Build Progress
Build in Progress...
600 volume 3D-Printer
Mar 27, 2024
Category
3D PRINTER BUILDS
Build Progress
Rezo 1390 100W CO2 Laser
Jul 26, 2023
Category
Laser Cutter Builds
Build Progress
Build Complete!
Sphinx 66
Apr 17, 2023
Category
CNC ROUTER BUILDS
Build Progress
Build Complete!
Dec 18, 2022
Category
Cartesian Style Bots
Build Progress
Build Complete!
Mar 21, 2020
Category
Build Progress
Build Complete!
Mar 4, 2021
Category
Build Progress
Build Complete!
7050 Sphinx
May 25, 2018
Category
Cartesian Style CNC
Build Progress
Build Complete!
My Lead 1010
Mar 18, 2024
Category
Other Style CNC Mills
Build Progress
Build Complete!
C-beam Machine - Modesty
Mar 18, 2024
Category
X/Y Table Style CNC Mill
Build Progress
Techsoft Roland TS-30 rebuild
Sep 6, 2023
Category
Cartesian Style CNC
Build Progress
Openbuilds 4x8 cnc
Aug 14, 2020
Category
Build Progress
Build Complete!
Sep 17, 2019
Category
H-Bot and Core XY
Build Progress
Sep 6, 2023
Category
CNC ROUTER
Build Progress
Build Complete!
Vulcan MAX
Feb 22, 2024
Category
Build Progress
Feb 23, 2024
Category
CNC ROUTER BUILDS
Build Progress
Build Complete!
BA3DP
Category
3D PRINTER BUILDS
Build Progress
Build Complete!
Z Floating Head
Jan 30, 2024
Category
Build Progress
Build Complete!
Nov 1, 2019
Category
Circuit - Software Project
Build Progress
Build Complete!
Sphinx 55
Feb 10, 2021
Category
Cartesian Style CNC
Build Progress
Build Complete!
Feb 28, 2018
Category
3D PRINTER BUILDS
Build Progress
Build Complete!
Hydraulic lifting table
Nov 30, 2017
Category
Everything Else
Build Progress
Build Complete!
My large machine 48 X 48
Nov 26, 2023
Category
Build Progress
Jul 18, 2022
Category
Cartesian Style CNC
Build Progress
Build Complete!
LEAD CNC 1010 (40" x 40")
Nov 24, 2023
Category
CNC ROUTER
Build Progress
Build Complete!
Apr 22, 2014
Category
Everything Else
Build Progress
WorkBee CNC Machine
Nov 20, 2023
Category
Cartesian Style CNC
Build Progress
Build Complete!
High Z Mod for Lead CNC
Oct 28, 2019
Category
CNC ROUTER
Build Progress
Build Complete!
Feb 14, 2019
Category
Laser Cutter Builds
Build Progress
Build Complete!
Ooznest OX CNC Machine
Sep 17, 2018
Category
Cartesian Style CNC
Build Progress
Build Complete!
Jan 14, 2018
Category
Delta Bots
Build Progress
Build Complete!
Sphinx 1050
Dec 4, 2018
Category
Cartesian Style CNC
Build Progress
Salmon Sphinx 1.0
Jul 22, 2017
Category
Cartesian Style CNC
Build Progress
Gauthali V2.0 DIY 3D printer
Aug 23, 2023
Category
H-Bot and Core XY
Build Progress
Build Complete!
Core-XY Cube
Sep 21, 2017
Category
H-Bot and Core XY
Build Progress
Build Complete!
M4: 1510SS Heavy Mk.I
Aug 22, 2020
Category
Cartesian Style CNC
Build Progress
Sep 2, 2014
Category
Build Progress
OneZ i3
Apr 19, 2017
Category
Build Progress
Build Complete!
C-Beam XLarge X/Y Table
Oct 25, 2019
Category
ACTUATOR
Build Progress
Build Complete!
Nov 18, 2018
Category
Everything Else
Build Progress
LEGO BOX
Jun 20, 2023
Category
Furniture Builds
Build Progress
Build Complete!
UltiBots CB3030 CNC Router
Jul 18, 2016
Category
Cartesian Style CNC
Build Progress
Beefed up Minimill
Aug 24, 2020
Category
Build Progress
ALl included interface
Apr 8, 2023
Category
CNC ROUTER BUILDS
Build Progress
Build Complete!
45W CO2 Laser Build
Jun 10, 2021
Category
Laser Cutter Builds
Build Progress
Build Complete!
Loading...
Loading Build images...
