      TITAN GAMBIT
      Features
      • TWIN X Axis rails, No more X axis TWIST.
      • TWIN T12 (12mm) lead screws drive every axis, X, Y and Z
      • High Z capability, 12mm twin screws drive the X axis up and down.
      • T12 Lead nuts power the drive train, say goodbye to machine chatter and lead screw whip
      • Torsion bearings on the X and Y axes, eliminates lead screw whip
      • All gantry plates are custom designed to be in unison with the machine.
      • M8 bolts on all wheel sets
      • Unique sled gantry houses the spindle and optional Rack / Pinion drive
      • Twin Nema motors on every drive axis for more force
      • Plate reinforced supports attach to the inner bed profiles and the inner C-Beams on the Y Axis, ensuring further rigidity for Y C-Beams.
      • The Sled overhang acts as a dust protector for the wheels (the overhang is where the optional linear guides fit)
      • Minimal Spindle hang eliminates spindle 'wobble'
      • Cable Chain support on the X axis
      • The design ensures all weight is balanced on the Y arms, for smoother motion
      Optional Build Design
      • 12mm Ball Screw option
      • Optional Linear rail and linear guide upgrade build designed (being tested) , no wheels, simpler assembly!
      Unique Sled Design
      • Fixed Z Gantry sled design as shown incorporated with High Y arms, for machining low or high
      • Sled with standard Z gantry, for those makers who would never machine high, Fixed Y arms.
      JayMcD likes this.
    Most Openbuilds kits suffer from the same problem. Larger builds need more rigidity, this kit provides that.
