BCN3D Sigmax + Voron = Sigron
Hey Everyone, this is my new IDEX 3D printer design. This is the start of my dream build that is an IDEX with a moving gantry. It has a 400 x 400 x 400ish build volume. The final build will be fully enclosed.
My goal with this printer is to build a printer that can print every filament type (excluding PEI, etc.) with ease.
I started with the BCN3D Sigmax R19 step file and modified the design to use aluminum extrusions and printed parts instead of aluminum sheet. I added 2 Voron Afterburner direct drive extruders and modified them to run on a single linear rail. I might try to use double linear rail for the x axis in the future.
Main Features:
- IDEX
- Moving gantry
- All linear rails
- Large build volume
- Direct drive
This is a work in progress, and I will continue to update it in the coming months. Any feedback is welcome.
Thanks for your interest
8/29: Added front belt mounts
8/29: Added bottom belts to design
Sigron IDEX
Build in 'Cartesian Style Bots' published by Troy Joachim, Aug 29, 2020.
BNC3D Signax + Voron = Sigron IDEX
Drew S, David E Maker, Loic_Jegou and 7 others like this. -
Build Author Troy Joachim, Find all builds by Troy Joachim
I want to build a high quality engineering grade printer at a lower cost.
