This is a purely concept build project using a spare equipment rack as the frame. The concept is to mount the bed to the floor of the frme, using a Y Axis actuator of 500 mm. The X Axis gantry of 450 mm will rise the Z axis height of approximately 1800 mm. Controller will most likely be Duet WiFi. Initial concept is threaded lead screws vs belts using Nema23 motors.
Server Rack Printer
Build in 'X/Y Table Style Bots' published by Dmknerr, Mar 15, 2017.
My first project build. Concept build to use an existing 7.5 ft tall server rack as the frame. This ptoject may never be completed.
Marshall Guillory and MaryD like this. -
Build Author Dmknerr, Find all builds by Dmknerr
Spare server rack going unused and wanted a third printer for large volume builds. -
Qty Part Name Part Link Comments 1 NEMA 17 V Channel Lead screw Bundle Kit 500 mm http://openbuildspartstore.com/v-slot-nema-17-linear-actu... Link with Motor for Y Axis 1 NEMA 17 V Channel Belt Bundle Kit 500 mm http://openbuildspartstore.com/v-slot-linear-actuator-bun... Link with Motor for X Axis 1 Duet Wifi Controller https://www.filastruder.com/collections/electronics/produ... Link includes 2A stepper drivers 1 NEMA 17 V Channel Lead Screw Bundle Kit 250 mm http://openbuildspartstore.com/v-slot-nema-17-linear-actu... Link with Motor for Z Axis 1 V Slot Linear Rail 20mm x 60mm Link 2000mm length for Z Axis 1 24V /14.6A Meanwell Power Supply http://openbuildspartstore.com/24v-14-6a-meanwell-power-s... Link SKU: 591 0 Link
