Inspired by @Giarc 's lathe build I decided to add a rotary axis to my Workbee.
First problem to overcome was the lack of height under the X gantry - I decided to raise the Workbee by 40 mm with longer Y end plates and replacing the 20/40 end frames with 20/80.
I intend to make some plates to mount the head and tailstock with an 80 mm groove underneath to register with the 20/80 bed supports, which will lay flat instead of vertical. I haven't decided whether to orient the Rotary axis on the Y or X axis of the workbee so those plates are still a work in progress.
So far I have designed an extended T-nut (V-slot slider) for fixing those plates to the bed support and designed and cut 3 out of the 4 longer Y end plates needed.
Rotary axis for Workbee
Build in 'CNC ROUTER BUILDS' published by Alex Chambers, Jan 4, 2021.
Adding a rotary axis to the Workbee 1010. Including height modifications to the Workbee.
Giarc, Mark Carew, GeoffH and 2 others like this. -
Build Author Alex Chambers, Find all builds by Alex Chambers
