      FB_IMG_1690407505398.jpg [GALLERY=][/GALLERY] The frame is made from very rigid 45mm aluminum extrusion, ordered cut to size from Misumi. Screenshot_20220722-050525_Facebook.jpg
      I had side and inner panels made from aluminum at a local fabricator using the dxf files in the build plans.
      The gantry is a drop in gantry purchased from Light Object.
      To mount the bed to the Z drive, I cut aluminum mounts on my Gatton CNC router. Other bushings and supports were printed on my 3D printer. again, all dxf files are in the plans. 20220327_171725_resized.jpg 20220330_152312_resized.jpg 20220331_170825_resized.jpg
      The bed uses 4 lead screws or ball screws, and a 15mm belt. It can be manually moved by hand, orset up with a nema 34 stepper motor. I used the motor and later switched from lead screws to ball screws. 20220814_202833_resized.jpg 20220811_134247_resized.jpg
      The electronics bay panel layout before installation. the board is just 1/2" MDF painted black and sealed. I'm using a laser power supply from Cloudray, Drivers for X and Y (and nema 17 stepper motors) came with the gantry. I had to purchase drivers for the Z axis and U axis (rotary) separately. I decided to go with a Trocen 7824 laser controller. A 24v and 12v power supplies, Relays for air assist solenoids, water chiller, exhaust fan, air compressor, and a circuit breaker for safety. FB_IMG_1690407579553.jpg
      I decided to mount the panel in the electronics bay, then start on the wiring, but much of the wiring can be done on the bench before installing the panel. 20220808_192602_resized.jpg 20220808_192613_resized.jpg 20220808_192623_resized.jpg FB_IMG_1690407469397.jpg
      The plans come with a dxf file for a switch panel using toggle switches, but I created a different layout that uses buttons out of black acrylic. 20220808_192531_resized.jpg
      1/4" acrylic panels are also used on the front and top of the machine as well. FB_IMG_1690407499358.jpg FB_IMG_1690407505398.jpg FB_IMG_1690407631394.jpg
      I used a 100w SPT laser tube with built in red dot. that made aligning the laser a breeze. 20230726_174911 (1).jpg
      Plans and bill of materials can be found at Rēzo 1390 plans
        Costs vary depending on components and features. fabricated aluminum panels can be substituted with acrylic panels. Z axis can utilize lead screws or ball screws, and motorized or manual bed lift. Options between controllers and electrical components. $5000-$6500
        Plans can be found at Rēzo 1390 plans
    I wanted to build a rigid, high quality co2 laser that could compete with and outperform commercial machines. i chose a 100w laser tube for a good combo of cutting and engraving.
    Designed by Jonathan Frost
    1 Plans https://rezo1390.bigcartel.com/product/rezo-1390-plans Link Plans and bill of materials sold by Frosty Designs
    0 Link
