I took a 1000x1500mm quenbe Pro from SPAM 3D and integrated the OpenBuilds Blackbox and Power Supply with High-Torque Stepper Motors.
I coupled the Y-Axes into a single port and will eventually use the Y2 port for a 4th Axis Rotary Tool. This will allow me to cut turned profiles along the 4th axis, along with inlays and scrollwork cut into the cylindrical blanks.
QueenBee Pro CNC Router and Lathe
Build in 'Other Lathe Build' published by Jason @ MCC, Jun 23, 2022.
A 1000x1500mm QueenBee Pro with a 4th Axis Rotary attachment/Lathe Bed.
Ted Moyer, Mark Carew and JDavis3rd like this. -
Build Author Jason @ MCC, Find all builds by Jason @ MCC
Cut inlay pockets and inserts into pool cues and other flat/turned projects. -
