Ducks and Background:
Paint, wood, hinges, duckies, and few screws were used to build the setting
To rock the ducks, a nema 23 stepper motor was used to move a mounted cart over two-8-mm aluminum rods.
The barrier mounted over a V-Slot® NEMA 17 Linear Actuator Bundle (Belt Driven)
To make the fast move, an Odrive board and a brushless motor has been used.
The code for motors, Nema 23 and brushless-outrunner-motor, has been provided on this build.
Quack Ball
Build in 'Camera Sliders - Rigs' published by hbtousa, Mar 5, 2018.
Quack Ball is a game in which the objective is to knock down moving ducks. The ducks are protected by a barricade that moves at a very fast speed. The game can be played individually or by two or more players. Each round consists of a total of ten targets to shoot and each player will have four balls to shoot. Prior to beginning play, a player selects how many ducks, maximum four, the player will knock down continuously. If player fails games is over for that player.
MaryD likes this. -
Build Author hbtousa, Find all builds by hbtousa
Put together a system that involves mechanics, electronics, computer software, and the most important part: creativity.Inspired by
Qty Part Name Part Link Comments 1 V-Slot® NEMA 17 Linear Actuator Bundle (Belt D http://openbuildspartstore.com/v-slot-nema-17-linear-actu... Link 1 Odrive V 3.4 https://odriverobotics.com/shop/odrive-v34 Link 1 ENCODER PROG 16RES SW TTL RADIAL Link 1 Single TB6600 Stepper Motor Driver Controller Micr Link 1 Nema 23 Stepper motor Sanyo Denki 142 ozin- Link 1 AC to DC Power Supply Triple Out 24V Link 1 GT2 16 Tooth Pulley 5mm Link 1 GT2 Timing Belt by the Meter 6mm width Link 2 8mm x 500mm Precision Chromed Rod Link 4 SC8UU SCS8UU 8mm CNC Linear Ball Mot Link 4 Sealed Ball Bearing 6x13 ID=6mm OD=13mm width=5mm Link 1 Leonardo R3 Pro Micro ATmega32U4 Board For Arduino Link 1 Brushless-outrunner-motor https://hobbyking.com/en_us/turnigy-aerodrive-sk3-4250-35... Link -
