This is my remix of the Prusa i3 Bear with IDEX. This is still a work in progress so any comments are welcome.
Modified pieces:
Everything else is either stock Prusa i3 MK3 or Bear parts.
- x-carriage-back
- x-end with the motor mount
- Z top mounts
- Extended Bear frame y extrusion
- Extended y linear rods
Future plans:
Prusa i3 Bear IDEX by TroyJoachim
- Use a Duet2 with an expansion board running RepRap firmware.
- Added a large touch screen and box to hold the mainboard. Maybe something more similar to the CR-10.
- Route cables out the top. I might add a something onto the extruder for better cable management.
- Drill and tap the extrusion instead of using brackets.
- Build the real version.
Prusa i3 Bear IDEX
Build in 'Cartesian Style Bots' published by Troy Joachim, Jul 3, 2020.
Remix of the Prusa i3 Bear with added IDEX
James Hsu, cffranchi, p2kwizard and 1 other person like this. -
Build Author Troy Joachim, Find all builds by Troy Joachim
I think that adjusting two extruders on independent Z axis will be easier then two extruders on the same X axis. I guess I will find out.Inspired by
Prusa i3 mks, Prusa i3 Bear, Zidex -
