I am updating this mill for use in my classroom. We have several across the district, and inherited a couple more without their control boxes/ISA cards.
At this point:
What got connected where:
- all axis and end stops are connected and functional
- the 1hp (5000 rpm) spindle is working through the analog 1-10v
- the manual controls on the mill for the spindle and E-stop function
To Do List:
- There are 2 @ DB9 Connectors and [email protected] DB15 Connector. I have attached how I connected them to the BlackBox controller.
- I use screw terminal breakouts and 20AWG 4 conductor wire to connect the breakouts to the Blackbox controller.
- For power, I connected both the spindle power cord (mine was a IEC 320 C13, I've seen some with a standard ground plug) and the main power cord to 120v. The Blackbox needs a 24v supply.
- The Steppers are Slo-Syn Motors M063-CS06 3.36VDC 2.9 Amps, 200 Steps/Rev, they are eight pin motors, but the original harness is only using four pins.
- Figure out travel distances
- Collect and add the GRBL settings.
- Build Enclosure for controller, power supply, and cable breakouts.
Connector Breakouts
Close Up of stepper motor panel![]()
X Axis Cover Removed![]()
Back panel removed showing spindle control
Pro Light 1000 CNC Machining Center Rebuild
Build in 'Other Style CNC Mills' published by AWoodbridge, May 3, 2021.
Replacing the Pro Light control box with a Open Builds BlackBox.
Bluegillman, Mark Carew, GeoffH and 1 other person like this. -
Build Author AWoodbridge, Find all builds by AWoodbridge
Modernizing a classroom mill to make it easier to work with. -
Qty Part Name Part Link Comments 1 BlackBox Motion Controller https://openbuildspartstore.com/blackbox-motion-control-s... Link 2 DB-9 Female Breakout https://www.amazon.com/Breakout-Connector-Serial-Terminal... Link 1 DB-15 Female Breakout https://www.amazon.com/Sysly-D-SUB-Terminal-Breakout-Rive... Link It's two rows like an old PC joystick connector not three rows like a VGA connector 1 20 awg 4 conductor wire https://www.amazon.com/dp/B07RHV5K5F?ref_=pe_1815430_2119... Link -
