It is a Core XY Laser Cutter/Etcher. Powered by a 3.5 watt blue laser.
My build is a Core XY system with a Z axis.
The laser module I am using has full power to the laser when the controller is not powered and the air pump is very noisy so I added a relay to turn the power supply on using the cooling enabled pin on the CNC Shield so M8 will enable and M9 will disable power to the motors, air pump, and laser.
The Build Area:
X: 601mm
Y: 798mm
Z: 60mm
Build Steps
- Download STL files https://openbuilds.com/attachments/phlux-core-xy-laser-echer-stl-zip.31707/
- Cut 2 750mm length sections from one of the V-Slot® 20x40 Linear Rail 1500mm.
- Cut 1 714mm length section from the other V-Slot® 20x40 Linear Rail 1500mm.
Phlux Core XY Laser Etcher
Build in 'Laser Cutter Builds' published by JCPhlux, Mar 3, 2018.
A 750mm x 1000mm Core XY Laser Etcher/Cutter. To cut down on cost I tried to have as many parts as possible be printed.
Spalding.a, jesussanchez, Mark Carew and 2 others like this. -
Build Author JCPhlux, Find all builds by JCPhlux
Have been wanting one for a while and my son asked if we could build it for his engineering fair at school.Inspired by
ACRO System -
