Hi everyone! The development of the OpenCase serves the purpose of offering a quick and easy solution to containing your controller and wiring, as well as offering mounting options to your machine. This case offers a wide variety of controller mounting options to match up with just about any controller.
OpenCase Mounting Kit please click here
OpenCase Assembly Video:
OpenCase Assembly (Using Xpro V4)
- 1/4" (6mm) Thick
- Mounting Options for xPRO Controller and Duet 3D Printer Controller Board
- Acrylic can be drilled to fit many other controllers
- Integrated 80mm cooling fan for maximum cooling on the drivers
- Mountable options to all sizes of V-Slot and C-Beam Linear Rails
Build in 'Circuit - Software Project' published by Mark Carew, Mar 13, 2019.
The OpenCase Mounting Kit makes wire management quick and easy!
To offer a simple solution for mounting controller boards. -
Qty Part Name Part Link Comments 1 OpenCase Mounting Kit https://openbuildspartstore.com/opencase-mounting-kit/ Link SKU 2615 12 Button Head Screws M3 (Singles) https://openbuildspartstore.com/button-head-screws-m3-25-... Link SKU 856 - Sold in Packs - You need 12 Singles 2 OpenCase Mounting Plate https://openbuildspartstore.com/opencase-mounting-plate/ Link SKU 2605 4 M3 Hex Standoff (4 Pack) https://openbuildspartstore.com/m3-hex-standoff-4-pack/ Link SKU 2590 - Sold in Packs of 4 - You will need 1 Pack 4 Nylon Spacers 1/8 (Singles) https://openbuildspartstore.com/nylon-spacers-10-pack/ Link Sold in Packs of 10 - You will need 4 singles 2 Low Profile Screws M5 15mm (Singles) https://openbuildspartstore.com/low-profile-screws-m5-10-... Link SKU 922 - Sold in Packs - You will need 2 Singles 2 Slot Washer - 15x5x2mm https://openbuildspartstore.com/slot-washer-15x5x2mm/ Link SKU 185 2 Aluminum Spacers 3mm (Singles) https://openbuildspartstore.com/aluminum-spacers-10-pack/ Link SKU 175 - Sold in Packs - You will need 2 singles 2 Drop In Tee Nuts https://openbuildspartstore.com/drop-in-tee-nuts/ Link SKU 230 4 Button Head Screws M3 16mm (Singles) Link 8 Tee Nuts - M3 (Singles) https://openbuildspartstore.com/tee-nuts-m3-10-pack/ Link SKU 2165 - Sold in Packs - You will need 8 Singles -
