This is my Workbee 1010 in the blackout version. I used Nema 23 bipolar, 340 oz/in stepper motors from Stepperonline.com. I am using a grbl board with 1.1 firmware. My microstepping is set at 1/16. I primarily use Fusion 360 for design and Estlcam to generate g-codes. My controller is Bcnc and is run on a raspberry pi and 7 in screen. So far this setup has worked perfectly.
My Workbee 1010
Build in 'CNC ROUTER BUILDS' published by Doug Rowley, Feb 2, 2019.
This is a workbee 1010 build using the mechanical parts from Open Builds. The electrical and electronic parts were from a prior build of a Root 3 CNC by Sailor Pete.
Build Author Doug Rowley, Find all builds by Doug Rowley
I am using this machine for home hobby woodworking
