      4/5,
      1 votes
      20200712_111048.jpg 20200712_111103.jpg 20200730_112023.jpg 20200730_112034.jpg 20200730_112048.jpg 20200730_112056.jpg 20200730_112113.jpg 20200730_112140.jpg
      Primary Changes;
      - 2040 extrusion elevated base
      - Base mounted Noise dampening Polyurethane feet
      - Belt driven X-Axis configuration to reduce width
      - Custom Front access Power switch, USB, Collet storage, Router Wrenches, and XYZ Probe
      - Custom anodized plates, end stops, and router mounts (wanted something that looked a little different than stock)
        Special Thanks to Chris Laidlaw for the custom Sphinx plates, End plates, Z-axis gantry and custom Z-axis motor mount!
        If you are interested in a custom set of plates modified for using the MGN 12 rails and MGN12H sliding blocks, you can buy it from Chris at his eBay store here https://www.ebay.com/itm/264458290488”
        All plates were anodized and dyed by myself using Fiery Red and Jet Black dyes from Caswell (utilizing 720 anodizing rule).
    Chris Laidlaw, Sorin Iliescu, Kenneth Witthuhn
