      2 votes
      Work in progress, will update soon.
      Inductive limit switches
      Control panel mock up.
      Spindle water cooling setup with 6x 120mm Fans and 60mm radiators.
      Noga Minicool mist / air nozzle
      Development drawings, also shows placement of 16mm Ball Screws.
      T-Slot Rail Supports in Place.
      Nema 34 & 1610 Hiwin Ballscrew Support plates.
      Drag chain support and monitor bracket.
      Water cooling mounting plate.
      16mm Ball screws fitted.
      Rear Gantry brace.
      NEMA 34 Mounts and motors installed.
      Drag Chains and Nema34 X motor installed.
      Control Panel and water cooling panel mounted.
      Control panel wired up.
      Playing with concepts for new Y axis Gantry.
      Amito, Timstone, bramuss and 8 others like this.
