      This build is in progress, And since is my first build post I did not know exactly what to post. So I will be updating this post as a finish the remaining items
      An Update, After finalizing my tests for the drivers I found no board that can handle 8 motors. So I had to revert my build to a LEAD machine of sorts.
      However before the disassemble the machine was very rigid, I applied 250N to the top and deflection was the expected .3mm at the top of the Z-Axis. The deflection on the X-Axis was .2mm. I did not measure the Y axis.
      Unfortunately it will be a while before I update this build.
      Please let me know if you have any thoughts on the project.
    AS mentioned, I needed more Z axis clearance to use all 6 axis (still in progress).
    A combination of the LEAD machine and the WorkBee
