This is my design for a CNC Laser for more information like BOM list you can visit
ME - Laser CNC it's where I will always have all the latest updates.
You can see my other future projects here ME-Machines
Still in development i'm building two prototypes one for me and one for a client.
The drawing that's in the 3d warehouse is what I'm using for the prototypes
If i make any changes i post here, but please keep in mind that it's still under development.
You can help support my work by purchasing the full model here:
ME - Laser CNC 3D sketchup Model
Or here:
ME Laser CNC 3D Sketchup Model | Etsy
I remixed the PLAY3Rone977 user height adjustment system
Height Adjustment Ortur Laser Master 2, Höhenverstellung Lasermaster 2 by PLAY3Rone977
all credits from this system go to him, please support his work
Donwload STL Files from:
ME - Laser CNC by EdgarMata
PrusaPrinters
Controller Board
I use the Makerbase MKS DLC32 board as a controller, which is an offline engraving master control kit designed for desktop engraving machines. The hardware is equipped with a 32-bit high-speed ESP32 module, has built-in WIFI function, and directly drives a 3.5-inch touch-sensitive color dislpay.
It can perform fast engraving and also has a WEB page as a control interface.
This board can also be controlled by a mobile APP with various functions, as well as can be used with LaserGRBL and LightBurn PC software.
For more information about this board you can consult the official page Makerbase as well as the GitHub page.
I'll add photos of the prototype here later:
Road Map
Improve 3D drawing
Design enclosure box
- Add better wire strain relief system
- Adjust board location for better access to power supply plug
- Adjust X-Axis height to engrave thicker pieces
- Add emergency stop
Design assembly instructions
Design user manual
Changelog:
19 - Nov - 2021
Add 3D pinted parts to BOM list, you can download the stl files from the links above
ME - Laser CNC
Build in 'Laser Cutter Builds' published by Edgar Mata, Nov 16, 2021.
Build of a small laser engraver using V-slot profiles and 3d printed parts
noursbricoleur likes this. -
Build Author Edgar Mata, Find all builds by Edgar Mata
This project started out as a solution to solve a problem at the company where I work at the moment and has since evolved into something that I will share here... -
