I have somewhat limited space to place my router, so I decided to modify the LEAD 1010 to have a LEAD 710 instead. The X Axis C-beam has been reduced from 1000mm to 700mm. All other X axis dimensions from the LEAD 1010 were modified down 300mm and parts ordered. I'll post my parts list once I've had a chance to review it for where I had a few problems.
I took pictures for most of the build, though near the end, I was just trying to push through and finish. I still have to finish hooking up the spindle to the VFD and water pump before I can use it, but currently I have the Black Box set up and functionally running. I can move all the axes and home the machine.
Once I've got the spindle running, I'll calibrate the axes and I'll start tuning for my maximum travel speed.
LEAD 710 with High Z mod
Build in 'X/Y Table Style CNC Mill' published by Torin3, Nov 14, 2021.
Overview of a 700mm x 1000mm machine based on the LEAD design and with the High Z mod from the start. Will have a parts list you can use to build yourself if you like the formfactor
Chris Norberg, TimATX, Richard148 and 2 others like this. -
Build Author Torin3, Find all builds by Torin3
Needed a machine slightly smaller than the LEAD 1010.
