View attachment 16014 View attachment 16014
USE PROTECTIVE GLASSES / GLOGGLES AND SHIELDING !!!
This is the bottom of the mount. Its a stock Router / Spindle mount from OpenBuilds Part store
(Router/Spindle Mount). I used the protective Laser Optical Density Shielding (250nm to 520nm Laser Shielding – 12″ x 12″ | J Tech Photonics, Inc.) and cut sides and center plate. The center plate was cut with a scroll saw as I did have have a machine to cut them out. I traced the parts onto the protective shielding and cut them out.
The "L' angle 3/16"x 1" x 1" is used to hold the Laser assembly and mount to the rear router/spindle bracket.
I plan on also using protective shielding sides around my machine to prevent any injury to my eyes.
Laser Mount
Build in 'Laser Cutter Builds' published by blindflight, May 19, 2016.
This is a mount I wanted to build for a laser project using OpenBuilds part router mount.
Use "EYE PROTECTION !!!!!!
Special thanks to : OpenBuilds Store OpenBuilds Part Store
OpenBuilds: Build List | OpenBuilds
J Tech / Products | J Tech Photonics, Inc.
Bernie CLark, Paul Pridday, Chetan PM and 6 others like this. -
Build Author blindflight, Find all builds by blindflight
I made this build because I am going to build a laser cutting machine
using OpenBuilds parts (OpenBuilds Part Store)Inspired by
C-Beam machine -
Qty Part Name Part Link Comments 1 Router/Spindle Mount http://openbuildspartstore.com/router-spindle-mount/ Link Great Router Mount & Fast shipping service on all items 2 6mm Aluminum Spacers http://openbuildspartstore.com/aluminum-spacers/ Link 12 Low Profile Screws M5 http://openbuildspartstore.com/low-profile-screws-m5/ Link Always great products 1 2.8W Laser and Driver Kit, U.S. https://jtechphotonics.com/?product=new-2-8w-laser-and-2-... Link Items included in kit, see link. 1 6061-Aluminum "L-angle" Link I used scrap 3/16 angle ( can use 1/8") 1 250nm to 520nm Laser Shielding – 12″ x 12″ https://jtechphotonics.com/?product=445nm-laser-shielding Link Protect your EYES with this sheilding !! 0 Link 0 Link 0 Link -
