Goals:
- Be as space efficient as possible.
- Be able to cut a 24" x 48" sheet of material.
- Self contained; everything needed to operate housed within
- As few unique extrusion lengths as possible
- Ease of assembly
Specs
Cut Travel: 650mm x 1250mm x ~100mm
Machine Dimensions: 950mm x 1430mm x 390mm
Power: 60W CO2
Controller: Ruida RDC6445G with Lightburn
Frame: Misumi 30 Series held together by a mix of printed parts and 1/4" aluminum plates.
Motion: MGN12H on X and Y, Quad 8mm lead screw on Z
Cooling: 360mm radiator with tube reservoir
Air Assist: Yes
Ventilation: Onboard vacuum with external 3" or 4" duct attachment
Estimated Cost: $1500
Notes
- I only had enough dimension information to make a very educated guess as to where the beam path will be. However, I can't design the head portion without having the unit in hand.
- After a little over two years worth of iterations, I don't think I can really do much more with it. I would like to have this completed by the end of the year.
- A detailed BOM is slowly being pieced together.
KRE CO2 2x4 Laser
Build in 'Laser Cutter Builds' published by Kevon Ritter, Sep 6, 2020.
Large Format CO2 Laser Cutter
You, SteveYYC, RaketenH0rst and 16 others like this. -
Build Author Kevon Ritter, Find all builds by Kevon Ritter
