This build was very simple, it is just a counter top shelf meant to be a space saver. It was designed to raise my toaster oven for easier use and create a spot for storage of bagels, muffins, etc. Just another way to use Vslot, you can modify this to fit your needs. I have attached some pics start to finish.
V-Slot Space Saver Build
SketchUp File included
Kitchen Space Saver
Build in 'Furniture Builds' published by Tinker, Aug 7, 2015.
The frame is made from all open builds parts, add the rubber feet and pads for the glass. The glass is clear 12" x 16" x 1/4" with a polished edge. A light basket slides on the countertop.
The rubber foot pads and under glass pads grip very well to keep the shelf stable
MaryD, Mark Carew and Rick 2.0 like this. -
Build Author Tinker, Find all builds by Tinker
Improve use of kitchen countertop space.Inspired by
Needed to build this, Vslot looked easy -
Qty Part Name Part Link Comments 1 Vslot - clear - 20x20 X1500 http://openbuildspartstore.com/v-slot-linear-rail/ Link cut into (2) 12" , (2) 8" , (4) 4" lengths *both ends tapped to M5 4 cube corner connector http://openbuildspartstore.com/cube-corner-connector/ Link could also be used to connect the side rails and reduce the cost of your build 4 Black Angle Corner Connector http://openbuildspartstore.com/black-angle-corner-connector/ Link to position side rail which is optional 4 End Caps http://openbuildspartstore.com/end-cap/ Link to finish the leg bottom, use 8mm screws 12 tee nuts http://openbuildspartstore.com/tee-nuts-25-pack/ Link for use with corner connector which is optional 12 5m low profile screws http://openbuildspartstore.com/low-profile-screws-m5/ Link 16 screws @ 8mm, 8 screws @ 10mm (use 10mm with cube connectors) 8 Rubber Pads Link buy pads of your choice for under glass and feet 1 12"x16" x 1/4" clear tempered glass,edges polished Link you can pay more for smoked glass, rounded edges or use another material 1 wicker basket - Top size:15.74" Lx 11.4" W x 3.15" Link you can modify your build for any size or kind of basket 0 Link -
