"Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away" and this is OPENDUILD's ACRO model...
I would like to share the modifications I have made to the original design in order to add a z-axis and try to use a Dremel with this machine.
The extra weight of the z-axis minimize the maximum speed of the machine , due to vibrations , especially to the 1000mm 2040 v-slot profiles of the y axis , and this was not good especially when I wanted to use my Endurance 10W laser at high speeds.
For this reason I reinforced the whole frame of the machine...
There are photos from two different machines , 1010 and 7510.
At the 7510 instead of bolting a 2020 tslot to each 2040 v-slot of the y axis , I cut in half with the table saw a C-beam , trasforming it to an L-beam !
The floating z-axis attachement is working with rare earth magnets.
When I clean a bit the drawings I will upload also the dxf files for the build.
Thanks a lot !
Michail
5-9-2021
.dxf files uploaded !
Build in 'Cartesian Style CNC' published by Michail, Sep 5, 2021.
modifying ACRO
Tomas Pontes, reza janati and Mark Carew like this. -
Build Author Michail, Find all builds by Michail
ROUTY -
