High Z Modification For Lead CNC
Take your LEAD 1010 to new heights with our easily adaptable High Z Modification!
With 8" of clearance for the Z-Axis this modification brings your manufacturing capabilities to a whole new level! The LEAD 1010 is a true modular CNC design, and this modification is just the beginning of what can be done with your machine. The SKY is the limit with the LEAD 1010! Get Yours here: High Z Mod
Modification Specs:
- This modification is for the LEAD CNC Machine
- 8" of clearance for Z-Axis
- Additional X-Carriage and C-Beam for added strength
- 500mm Z-Axis configuration
- Adjustable mounting configuration for Z-Axis
- Rigid modification design including additional framing components for added strength
- Precision Collet used for extended bit lengths
* When using an extended bit we recommend the use of softer materials, such as wood and foam. However, you can lower the Z axis down and cut harder materials just like the LEAD CNC.
- Woods Hard/Soft
- Plastics
- Aluminum
- Foams
Gallery:
High Z Modification Build Video:
High Z Mod for Lead CNC
Build in 'CNC ROUTER' published by Mark Carew, Oct 28, 2019.
Juan Jose, TOMMY DUGGIN, Thasspong and 12 others like this. -
To display the modular nature of the LEAD CNCInspired by
The LEAD 1010's modular capabilities! -
