This is where I am at right now. I'm still trying to figure out where to attach the cable chains.
This picture shows all the components I was able to machine using the Shpinx CNC. The white blocks are Delrin (Acetal) that I will machine into the ball nut housings.![]()
The Acetal blocks squared up on the mini mill.![]()
Boring the hole for the ball nut.![]()
Acetal ball nut housings and modified ball nuts. The flanges were ground to allow clearance inside the cbeam.![]()
Here's my method for attaching the angled piece that supports the Y axis linear carriages.![]()
Ball nut housing pocket. I had to add the dog bones later as I forgot them initially.![]()
Finished ball nut blocks![]()
Trying to keep a low profile inside the cbeam.![]()
I had to keep very tight tolerances for these to work together.![]()
Captive nut pockets as I can't reach all of these once the plates are installed.![]()
I had to install TouchDRO on my mini mill as I still had the X axis plates left to machine and no operational CNC at this point.![]()
These were fly cut above and the surface finish is meh but I bought a shell mill and you can see the difference below.![]()
This picture was actually take before I installed the DRO and I was till using blue ink.![]()
Looks like I need a small grease gun nozzle haha![]()
Represent!!![]()
Working on the Y axis motor standoffs. The standard 40mm won't work for me. I had to make these 55mm.![]()
55mm Y axis standoffs (Acetal)![]()
GRANITE 1.0
Build in 'Cartesian Style CNC' published by Michael.M, Dec 25, 2018.
This machine has been in the works for quite a while. Most of the plates were cut with my Shpinx machine. I have a lot more photos and information to share soon.
mautilux200, Adam's, Tony Wardle-Winship and 90 others like this. -
Build Author Michael.M, Find all builds by Michael.M
Qty Part Name Part Link Comments 10 PLN-05N Inductive Sensor https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww... Link
