Project started 3 years ago as my bachelors project and continued as main part of my Master’s degree final project.
First version was made with old printer and scanner parts.
Then it was upgraded with Nema 17 motors and rail system.
For final version aluminium extrusions were added and V slot rail for main axis, also for easier tool change drill chuck was added.
Its controlled with arduino uno and cnc shield with a4899 drivers through G-code sender.
The way it works, carbon fiber tow ( 12K ) passes through epoxy "bath" whole part is moving up and down, then is winded on steel rail tube which is rotating, usually do 4 passes and after that filament is pressed with clear tape to compress it for better adhesion then curing 12-24h and its ready for cutting and other finishing process.
Main purpose is to make carbon fiber tube for office supplies( fountain and mechanical pen ) and maybe few drone frames etc.
A bit of augmented reality:
1. Scan QR code with mobile ( it will redirect you to glitch )
2.On Glitch go to sunglasses icon ( left top corner ) you will have to allow use of camera
3. With camera on search for Hiro marker ( it work on screen but works better if its printed )
Future improvements:
Ruby script ( program for winding on specific angle etc )
Another rotation axis
Filament winder ( carbon fiber )
Build in 'Everything Else' published by Kanu, Mar 9, 2021.
Carbon fiber filament winder
Build Author Kanu, Find all builds by Kanu
Qty Part Name Part Link Comments 1 V-Slot® 40x40 Linear Rail https://openbuildspartstore.com/v-slot-40x40-linear-rail/ Link 40x40mm, 1m -
